Hello, I'm new to these forums, I'm not too sure if I'm posting in the right section... anyway I was wondering, what do I do if a worker stops in Prime95? Because with IBT, I was stable with 20 runs. My current OC and hardware are:
Gigabyte 990fxa-ud3
1090T BE
Multiplier: 18.5x
FSB: 228mhz
Vcore: 1.475v (bumps to 1.54 under load, LLC is set to Regular, don't know why this happens)
NB & HT Link Frequency: 2280mhz
So, should I revert to my stable Prime95 settings? Because, to be honest, I don't know what they are. I've been using IBT because it's much faster...
Anyway, here's my Prime95 log.
[Tue Oct 09 08:21:43 2012]
Self-test 640K passed!
[Tue Oct 09 08:37:22 2012]
Self-test 8K passed!
[Tue Oct 09 08:45:01 2012]
FATAL ERROR: Rounding was 0.4990234375, expected less than 0.4
Hardware failure detected, consult stress.txt file.
23 minutes and worker #5 stops working. So I consulted stress.txt and it led me here.
Also, while I'm here, would anyone know to increase CPU NB voltage on Gigabyte 990-fxa-ud3? In BIOS, there's NB voltage, which is for the mobo NB, right? And then there's CPU NB VID Voltage, which I'm not too sure is the same as the CPU NB voltage...
Any response is appreciated, thanks in advance.
Gigabyte 990fxa-ud3
1090T BE
Multiplier: 18.5x
FSB: 228mhz
