- Dec 16, 2012
Hello guys! Need some help from the Pro's!
So basically i have been struggling to get a stable overclock on my cpu since day 1. The issue is (and im wondering if this is normal or not) the cpu clock speed keeps jumping from 4.427Ghz to 4.399 Ghz at idle and full load. Same thing happens to HT (2.213Ghz - 2.199Ghz) & Memory Freq (805.01Mhz - 799.96)
Here are the hardware configurations listed below:
AMD FX4100, Biostar A880Gz, 8Gb Dual Chanel Ram, Nvidia Geforce GTX 550TI, 32Gb Patriot Torx 2 SSD, 500GB storage drive (don't remember model),600w Silancer MK3 PPCMK3S600 PSU.
Here are the BIOS configurations listed below:
C1E, C6, C State, UCC, Core Boost, Disabled.
High performance Computing, Enabled.
SATA Controller is set at AHCI.
CPU: X22 Multiplier, Voltage: 1.4000V
NB: Stock Voltage: 1.2375V
SB: Stock Voltage: (Don't remember)
HT: Stock Voltage 1.22V
RAM: Stock 1600Mhz, Voltage: 1.5V FSB : DRAM 1 : 4 Timing: 9,11,11,28,40
Temps are good, 41-44C Max Load, 9-11C Idle.
(Going to change case fans sometime this week for higher CFM rated fans, because my case fans barely move any air lol -.-
So what can it be, i have tried multiple set O/C configurations but no no avail my clock speed still jumps around no matter what the setting is at...
Should i increase my HT & NB Voltage and see if that will stable the clock speed?
I have tried to increase CPU Voltage but anything past 1.4125 crashes, Doesn't even POST... which leads me to belive it doesent have enough Voltage to either HT, NB or Ram?
(Prime95 Stress test RESULT- In-Place Large FFT's Test!)
[Sun Oct 21 15:24:45 2012]
Self-test 480K passed!
[Sun Dec 16 10:09:28 2012]
[Sun Dec 16 10:22:17 2012]
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Self-test 128K passed!
*Fail @ 4.4Ghz 1.3875V*
[Sun Dec 16 10:48:20 2012]
[Sun Dec 16 11:03:57 2012]
[Sun Dec 16 11:19:27 2012]
Self-test 560K passed!
[Sun Dec 16 11:34:37 2012]
Self-test 160K passed!
[Sun Dec 16 11:49:41 2012]
Self-test 640K passed!
[Sun Dec 16 12:04:44 2012]
Self-test 224K passed!
[Sun Dec 16 12:20:11 2012]
Self-test 720K passed!
4.4Ghz 1.4000V Pass, However i noticed that cores were on different steps core 3 & 4 were about 2-3 tasks ahead of 1 & 2. So i stoped.
Now runing P95 on 4.4Ghz @ 1.4125 V Temps max @ 48C.
Thank you for any help and taking your time to help me out, much appreciated!!
*Edited some Grammar*
