- Apr 27, 2003
hey all i have a hp laserjet 4 connected to a windows 7 computer and it works great, i had windows 7 installed on a laptop i was using as a desktop but something happend and now it wont start.
so i dug out my hackintosh and was going to reinstall windows 7 but couldnt find my disc so i used my copy of xp home and it works ok for my uses.
but now i need to share the printer from windows 7 64 bit to windows xp 32bit and some times it will work but after a restart it wouldnt connect any more and i would have to delete it and readd it to get it to work but now that does now even work.
i can send a test print but after a couple of minutes it fails, is there something im doing wrong on xp? it worked fine windows 7 to windows 7. any help and advice would be great
