- Feb 28, 2006
- North Louisiana
it is an Aopen F70PS .. prob about 2 years old. this problem started about a month ago but happened rarely, now tho it seems to happen more often ...
here is a breakdown of what it is doing....
if you have to shut the computer off and / or monitor .. and turn it back on later ... the little power light on the front will just blink rapidly and the LCD does not come on, (the PSU for it has it's light lit up and when i checked it with a multimeter it seems to be putting out spec according to label) ...
after a while, sometimes, the power light will go solid green and the monitor will come on all the way .. and work fine till the next time it has to be turned off ...
what could be causing this? .. what else should i try to check and see ...
it seems almost like the power supply isn't putting out enough juice to start the monitor? ... i have tried it (the montior and ps) on another computer and it does the same thing .. and the other montior on that computer works fine .. so it is something with that monitor...
