- Jan 12, 2006
- Warren,MI, USA BABY!!
- Thread Starter
- #41
Max0r said:Hey man, I'm rooting for you! When you paint the case black, what happens with the screw holes? Any complications when you use screws and stuff? Paint chipping? This is for my later reference since I'd like to paint a case black in the future.
i did place tap over the holes to porevent paint fffrom getting in but that dident matter, screws go in fine as long as you dont lay the paint on to heavy you should be fine ^_^, i'll try and see if i can get some pics up before i go to work
