- May 28, 2005
- Tigard, Oregon
Well, I have decided to start a new project, Project: Blue II.
I will be taking a Chenming "Dragon" (yes another one) and modding it for a new watercooled setup.
Modding To Acheive:
- Bottom PSU mount
- Top radiator mount
- 120mm intake and exhaust
- and more!
Components:
MOBO: ASUS A8N32-SLI
CPU: Undecided
Video Card: eVGA 7800GT
Memory: OCZ Gold Edition 2GB (2x1GB) DDR500 (PC4000) - HAVE
HDD: Western Digital 36GB Raptor (for OS and games) - HAVE
2nd HDD: Undecided (around a 200GB storage drive)
Optical: Plexor PX-716SA/SW SATA Drive - HAVE
PSU: PC Power & Cooling 510W SLI
Case: Chenming "Dragon" (outragiously modded) - HAVE
Cooling:
RAD: Black Ice Extreme III - HAVE
Pump: 2x Swiftech MCP655 - HAVE 1
CPU Block: Swiftech STORM G4 - ON ORDER
GPU Block: None for now
Reservoir: Going T-Line Instead
Fans: 16x Panaflo M1A's - HAVE
So my first decision is where to mount the radiator. Im thinking Im going to go with the http://www.frozencpu.com/ex-rad-12.html]Danger Den Black Ice Xtreme II and mount it up top of the case since the PSU will be at the bottom.
Now should I mount the RAD externally with the fans inside the case or just have the whole shebang inside?
Thanks
UPDATE: I updated with some of the components I will be using.
UPDATE: I added what memory I will be using.
Thanks
Modding To Acheive:
- Bottom PSU mount
- and more!
Components:
CPU: Undecided
Cooling:
Thanks
Thanks
