- Feb 1, 2003
- The Hammer, Ontario
- Thread Starter
- #241
Skeen said:So with the valve on your water line, you would run the water from the line into your cpu block and then back into the line. As far as money, would that be like keeping a faucet on all the time?
If that somehow could work, that'd be sweet.
You're close ... I would 'tap' the water BEFORE the water meter. Then expell the heated/used water directly into a drain.
Cheapest water cooling EVER!
No pumps, resevoir, radiator or upkeep! Virtually unlimited pressure/volume.
hmmm
