- Dec 5, 2004
- Milwaukee, WI
**Sigh** Looks like Sneaky’s at it again – this time with a custom case from Mountain Mods, plus a few other new toys and mods thrown into the mix as always
This time around I went into a little more detail with the spec/supply list, but hey, now you can follow me with the uber-tiny little details that I pay attention to
Planned Specs:
Case/Components:
-Enclosure: Custom “Black Wrinkle” Powdercoated Mountain Mods U2-UFO w/ Original Top - HAVE
-Processor: Intel Pentium D 920 Presler - HAVE
-Motherboard: Asus P5WD2-Premium 955X - HAVE
-Memory: 2GB (2x1GB) OCZ DDR2-667/PC2-5400 Platinum Enhanced Bandwidth - HAVE
-Graphics: Sapphire ATI Radeon x1900XTX 512MB PCI-Express x16 - HAVE
-Audio: Chaintech AV-710 7.1 - NEED
-Storage: 2x Hitachi Deskstar T7K250 250GB 7200RPM 8MB cache SATA II (RAID 0) - HAVE
Seagate 120GB 7200RPM 8MB cache IDE (backup drive) - HAVE
-5.25 Device: Black Samsung 52x32x52x16 CD-RW/DVD combo drive - HAVE
-3.5 Device: Black Sony 3.5" Floppy - HAVE
-Power: Zippy/Emacs PSL-6701P-SATA 700W PSU w/ Full PFC - HAVE
Water Cooling:
-CPU Block: Little River Water Blocks Storm G5 - HAVE
-GPU Block: Swiftech MCW60 w/ DD Maze4 Mounting hardware - NEED
-CPU Radiator: Thermochill PA 120.3 Radiator - NEED
-Pump: Iwaki RD-30 24v DC pump - NEED
-Pump PSU: Meanwell S-240-24 - NEED
-Fillport/Reservoir: Clear Danger Den Dual 5.25" Bay Reservoir - HAVE
-Tubing: Masterkleer 1/2" ID, 13/16" OD (5/32" Wall) Tubing - HAVE
-Hose Clamps: 20x 316 Stainless Steel Worm Drive Hose Clamps 1/2" band 7/8" max. ID - HAVE
Misc. Cooling:
-Northbridge Chipset Cooler: ThermalRight NB-1C w/ Delta 45x10mm fan - HAVE
-Radiator Fans: 6x Delta EFB1212LE 120x38mm fans- NEED
-Case Fans: 6x Delta EFB1212L 120x25mm fans - NEED
-RAMsinks: 8x Copper OCZ BGA RAMsinks - HAVE
Miscellaneous Parts:
- Matched “Black Wrinkle” Powdercoated Sunbeam 5.25" 4-Channel Rheobus - HAVE
-Matched “Black Wrinkle” Powdercoated Aluminum Lian Li 3.5 to 5.25 Bay Converter - HAVE
-Matched “Black Wrinkle” Powdercoated Aluminum Lian Li Floppy Drive Bezel - HAVE
-10x Chrome Plated Lian Li PCI Cover Plates - HAVE
-9x Black 120mm Wire Fan Grills - HAVE
-2x Lian Li V-series Stainless Steel Power Buttons - HAVE
-5x Water Clear Pure Green 5mm LEDs - HAVE
-5x Water Clear Pure Red 5mm LEDs - HAVE
-10x Chrome Mountain Mods 5mm LED Bezels - HAVE
Wiring & Wire Management:
-1x Black Rounded 18" Dual IDE Cable - HAVE
-1x Black Rounded 10" Floppy Cable - HAVE
-10x 12” 3-pin extension cables - HAVE
-10x 3-pin “Y” connectors - HAVE
-5x 4-pin molex “Y” connectors - HAVE
-5x 3 to 4-pin molex connectors/adapters - HAVE
-10 feet Black FLEXO PET 1/8" Sleeving - NEED
-50 feet Black FLEXO PET 1/4" Sleeving - NEED
-50 feet Black FLEXO PET 3/8" Sleeving - NEED
-10 feet Black FLEXO PET 1/2" Sleeving - HAVE
-8 feet Black Polyolefin 1/4” Heat Shrink Tubing - NEED
-16 feet Black Polyolefin 3/8” Heat Shrink Tubing - NEED
-16 feet Black Polyolefin 1/2” Heat Shrink Tubing - NEED
-4 feet Black Polyolefin 3/4” Heat Shrink Tubing - NEED
-500x Black Nylon 4” (5/8” bundle) Cable Ties - HAVE
-100x Black Nylon 3/4” 4-way Adhesive-Backed Cable Mounts - NEED
-1x Black AC Ryan Connectx ATX 24-pin Female connector housing - NEED
-1x Black AC Ryan Connectx EPS 8-pin Female connector housing - NEED
-1x Black AC Ryan Connectx Floppy Power 4-pin Female connector housing - NEED
-50x Black AC Ryan Connectx 3-pin Female fan housing - NEED
-40x Black AC Ryan Connectx Male 4-pin Molex Housing - NEED
-50x Black AC Ryan Connectx Female 4-pin Molex Housing - NEED
Miscellaneous Hardware:
-3x Sets of 10 Black Mutant Mods 6-32 threaded Thumb Screws - HAVE
-100x Neoprene Cushioning & Sealing Washer #10 Screw Size, .170” ID, ½” OD, .93” Thick - HAVE
-200x Black Oxide Alloy Steel Button Head Socket Cap Screw 8-32 Thread, 5/8" Length - HAVE
-100x Black Oxide Alloy Steel Button Head Socket Cap Screw 8-32 Thread, 1/2" Length - HAVE
-200x Black Oxide Alloy Steel Button Head Socket Cap Screw 6-32 Thread, 1/4" Length - HAVE
-100x Black Oxide Alloy Steel Button Head Socket Cap Screw 4-40 Thread, 1/4" Length - HAVE
-50x Black Oxide Alloy Steel Button Head Socket Cap Screw 6-32 Thread, 5/16" Length - HAVE
-100x Black Oxide Class 10.9 Steel Button Head Socket Cap Screw M3 Size, 8 mm Length, .5 mm Pitch - HAVE
-100x Black Oxide 18-8 Ss Machine Screw Hex Nut 8-32 Screw Size, 11/32" Width, 1/8" Height - HAVE
-100x Black Oxide 18-8 Ss Machine Screw Hex Nut 6-32 Screw Size, 5/16" Width, 7/64" Height - HAVE
Welcome to Project Three Mile Island - Revision D1
-Justin
Links to previous build threads:
P3MI Rev. B1: http://www.ocforums.com/showthread.php?t=352585
P3MI Rev. C1: http://www.ocforums.com/showthread.php?t=373851
P3MI Rev. C2: http://www.ocforums.com/showthread.php?t=404789
P3MI Rev. C3: http://www.ocforums.com/showthread.php?t=432533
