- Jul 29, 2006
Hey guys,
I've been working on this project for the past few months.. took a while off for sports, but now I'm back in full action, and this mod is almost done. Take a look!
Hey there guys, I've been working on this case for a while now, started around Febuary, but then took a few months off due to school/sports, but now I'm back in full swing, and things are looking up.
I'm sure a lot of you, like myself, love the UFO cases, but just have not gotten around to buying one, or its too expensive. I found myself with this predicament as well. So I decided to build one !
I made my first case over the summer, shown here:
While its not great, it opened me up to the world of modding.
I'm planning on replacing my current loop, minus my gpu block. Here's a list of the hardware I'm going to pick up.
1x Aluminum Sheet 18 x 18x 0.125
14x Aluminum L-profiles 18 x 18 x 0.125
1x Lian Li Replacement Removable Motherboard Tray
1x A.C. Ryan Constructx™ BayColumn510 UV Green
4x A.C. Ryan AcrylPanel™ 3mm Black
2x Startech 2.54mm Standard Jumper Caps
1x Digital Thermometer with Blue LED Back Light
1x Lian Li Dual PSU Bracket
4x Startech 2mm SCSI Drive Jumper Caps
Water Cooling - Petra'sTech
1x Gell Stuff
1x PT Nuke
10x Masterkleer 7/16
1x Pentosin
1x Swiftech MCR-320
1x D-Tek Fusion
4x Ek Barbs
1x Computer Screw Kit
I have not ordered the wc stuff yet, paypal transfer will clear the 15th, so I'll order that night. So if you have any suggestions, they're more than welcome.
I started construction today, so here are some pics so far.
.125=3.175mm- thick
Same with the alu sheet
looks good!
Temporary screws to hold everything in place before I get shorter ones. Wing nuts don't hold everything together tight enough, so I'll those will just some regular nuts. The new bolts will also be countersunk, with the nuts on the inside, for a more cosmetically pleasing look.
1x Gell Stuff
1x PT Nuke
1x Pentosin
1x Swiftech MCR-320
1x D-Tek Fusion
4x Ek Barbs
.125=3.175mm- thick
looks good!
