- Jul 29, 2006
- Thread Starter
- #21
And my new hd-rack and thumbscrews:
Ok, figured out what the problem was. The place where I soldered the original fan wire to the extension wire, what I call a "joint", was making contact with all the other joints, thus causing the electricity to get mixed up between the wires, thus causing the fans not work.
The situation didn't get better when I tried some bare copper wire (this was before I knew what the problem was).
So I went to Lowes, got some insulated wire, soldered everything back together, and to prevent the joints from making contact with each other, I put a piece of tape around each one of them. While this may sound ghetto, it worked
Got a two fans done, will work on the rest tonight.
Also picked up a tap set.. you'll see why in the coming days.
Joints
Heatshrinked joints to add stability
Did this to all six of them
The bare copper wire I was talking about
New, insulated wire
Taped joint
