Very nice.
I once made a hard drive case out of wood, it makes for much easier cutting than metal, wouldn't you agree? By the sounds of it, you probably have lots of fancy tools compared to my jigsaw that can't cut in a straight line, lol
Very nice.
Not too many fancy tools really, a jigsaw, rotozip, drill press, table saw, grinder and a Dremel.
Anyone know how to get incredibly strong glue off of plexi? My dad got slightly careless, and glue seeped out onto the front of the plexi.
If you can freeze the plexi this will weaken the bond, if the glue contracts at a slightly different rate. I'd then try a razor, tapping it with a small hammer if no progress by finger pressure. Caution: this may cause the razor to explode.
from many hardware stores u can buy a solvent try and get a nontoxic one and do it outside it worked wonders on my windows from where the decoarotr got paint and upvc sealent on them
