- May 29, 2002
- Japan/Daytona Beach
thorilan said:well look at it this way. A res main function is to bleed a system and store coolant and add as little restriction to a loop as possible while reducing inlet cavitation . the bay res only achieves 1 of these well and 1 not at all while the other is still slow.
the basic design principles for it do not put the air above but level with the out poting. not a single person can bleed thier entire system in under a minute using a bay res without changing its mounting to whats not intended by the manufacturer. if done it will still add more resistance.
in most cases people want a res for 1 of 2 reasons.
1. looks
2 functionality
functionality has more than just holding liquid as a requirement to be a Good design
here is an example of a good design as seen in an old thread
This is a classic straw man argument, thorilan. You need to know that at least one person here isn't buying it
Now, all of this may be true as you see it. I grant that. However, to say that your response was in line with the question asked is a bit of a stretch. I'm not trying to rag you out thorilan, but I think it's important to remember varied opinions are good for any forum, and should be encouraged.
Why are you trying to start a fight over this issue
thorilan said:well prove me wrong . everything is backed up and in its logical sequence.
ƒÓÒl said:You're still arguing with his wording, and lending nothing to the proof supporting your side of (what was once) the debate...leads me to believe you just want to argue instead of learning or teaching.
does not equal combative?Perseus said:For the record, I haven't once stooped to combativeness
Perseus said:though it seems to be fashionable among this forum’s glitterati not to quote directly as a form of snub.
Perseus said:TBH, most of what thorilan has contributed to this thread is simply incomprehensible and/or so self-serving as to not allow for a coherent rebuttal .
Perseus said:arrogance, straw men, circular logic, pseudo technical gibberish or blatant pandering to support my statements
Perseus said:Nor have I tried to force anyone to support statements that they didn’t make. Sadly, this isn't true of your "side", fool.
Perseus said:This being true, I'd suggest we all go back to using whatever we wish and allow others the same privilege. If further discussioNow, as far as I'm concerned, we've all had our say on this subjectn is required, please feel free to PM me.
No hard feelings.
Electron Chaser said:I like my res setup. Sure it is complete overkill but I had the space so I might as well use it. It looks nice and is very fucntional and if I ever decide to go with 2 seperate loops I can change it. Anyway here is a pic.
Im pretty sure those are these. (If that made sense...)jivetrky said:that is one pretty loop
what kind of resevoirs are those? I've never seen anything like them
BWR said:Im pretty sure those are these. (If that made sense...)
@ Electron Chaser:
Is that PrimoChill ICE in your loop? Oh and by the way, its looking GOOD. I presume it is for your Denali?
