- Dec 25, 2004
I've got a problem and I want to see if I can narrow it down to PSU or motherboard.
This is a SuperMicro H8QG6+-F 4 processor motherboard that had 4 12 core 6100 series CPUs in it. Powered by a Corsair RM1000 PSU. It had a USB optical mouse, a USB keyboard, and 4 120mm fans plugged into the motherboard fan headers. 1 SATA HD running on a native SATA power cable (no adapters). And 16 1GB sticks of DDR3 ECC Registered RAM.
It ran for 3 days, apparently fine. Then it stopped working. Trying to figure out the problem, I saw what is in the picture above. 1 burnt pin and what appears to be some scorching. It was running on a new surge suppressor strip, but not a UPS.
Now I've been having a lot of trouble with a similar 4P board and RMA was finally refused on it. The only things I've recycled from that experience was 3 CPUs, which were tested in a 2P SM board, and the RAM also tested in the 2P board, and the CPU HS/fans.
I purchased the RM1000 new specifically for this system. And it still seems to power the 2P SM board, though I haven't run it for more than about 20 minutes.
I'm probably only going to be able to RMA the new board once, and considering they run almost $800 a pop, I want to make REALLY, REALLY sure this isn't going to happen again.
You can read my 4P folding thread in the folding sub-forum for the full tale of woe.
Can anyone help?
Thanks!
Can anyone help?
Thanks!
