- Aug 6, 2003
- Irvine, CA
Well here is what im getting and the prices anything you would change or add? Id like a 2 barb cpu block i was shooting for the white water, but decided against it. Id rather use the TDX with nozzle #4.
CPU Block: Danger Den - TDX Block Intel Socket 478 - $52.95 + Accelerator Nozzles Package of 5 Nozzles and Wrench - $2.99
GPU Block: Cyclone Fusion HL V1.02 From Silverprop - $60.65 + OCZ Copper BGA Ramsink - $13.99
Pump: AquaXtreme 50Z-DC12 Mag Drive Inline Pump w/ 1/2" Barbed Fittings - $79.00
Radiator: Weaponized Dual Heatercore + Shroud - $79.50
Reservoir: Danger Den Fill Port - $11.95
Fan: Sanyo Denki 12VDC .52Amp Brushless DC San Ace Muffin Fans, Model 109R1212H101 – $4.99 (2x)
Hose: 10 FT General Purpose Clear PVC Tubing 1/2" ID – $.65 per foot - 5231K237
Hose Clamps: Metal Zip Ties
Fittings: "T" for 1/2" ID Tubing - $1.75 (x1)
Fluid: Distilled Water
Pentosin Antifreeze (Blue) – 9.86
