- Feb 23, 2011
- Toronto, Canada
- Thread Starter
- #21
Is there a formula to determine flow rate given pump psi and component pressure drop? or will i need more information? pump psi and pressure drop of the radiators i can find on skinneelabs but i dont see those listed for water blocks or fittings/tubing. Although i've read pressure drop for fittings and tubing are really quite small. Also, when determining how much many watts of heat and overclocks system will produce, do you use the processor TDP values? Or will wattage go beyond that when overclocking to the extremes?
