- May 13, 2003
Looking good!
How much rad do you have cooling those components? Do I see 3x120mm total?
You'll get max temps once the loop is saturated which takes at least 30 mins or so. Cinebench runs like, 10 seconds. If you want to check, run a CPU stress test and loop a 3DMark test at the same time for a while and see what temps are.
CPU idle seems pretty warm...47C...
Loop order doesn't matter so long as the res is before the pump for priming purposes. Temperatures with a properly flowing and radded loop don't vary by more than a couple of C at most.
Assuming 1.5 GPM flow, your loop cycles the water through ~5 times /minute (assuming ~1L of water)...it isnt sitting in places long enough to make a huge difference like you think. It's in the watercooling sticky threads too.
What's your flow like? What's your pump set to?
Like I said, loop order doesn't matter much... take a look at the watercooling stickies.
At this point, results in shirt benchmarks are irrelevant. They are scoring fine, but at this point I'd work with stress tests instead of these teaser things that run for a couple of mins.
I really am not sure which fans are which, lol. Front/sides/bottom = intake, top/rear = exhaust is the gerlneral rule of thumb.
Again.... what's your flow rate? Whats the pump set on? You've got 3 rads and 2 blocks so that can be restrictive.
