- Jan 26, 2011
Ive had a hunt and cant find a answer to this
I have just bought and odin gt 800w to power 2x OC 470`s and an OC Q6600 after my BFG 680w Blew.
My issue is that the 12v rails are split badly
12v1 - 18A (OCP 25A) CPU
12v2 - 18A (OCP 25A) PCIE 1
12v3 - 25A (OCP 30A) PCIE 2 + 3
12v4 - 25A (OCP 30A) PCIE 4 + molex
The problem is that my GPUS are capable of just over 30A (so 15A on each each) and trip the PSU, however over all of the PCIE Rails there is enough power to keep me below the OCP limit, the problem is that no matter which way i split the pcies over my GPU`s at max stress testing i can go over 30A on the middle rail whilst having 10-15A spare on the other 2 rails.
I NEED to distribute power better???
I have one GPU that pulls a lot more power than the other id say GPU1 - 35A GPU2 - 30A
given that no pcie pulls more than 18A then rail 1 is fine as one half of the GPU1
this leaves me about 47A left over 2 rails which are rated at 25A BUT its actually logically going to be split at 18/30 (Back over OCP).
My question is, can i combine the remaining 3 PCIE lines (2 rails) into one and then send power to the cards to essentially balance the load between them
12v2 - 18A (OCP 25A) PCIE 1 -> GPU1
12v3 - 25A (OCP 30A) PCIE 2+3
> ALL Combined then split to GPU 1 + 2
Physically
GPU1 --- 18A ----------------------------------- 12v2 (18A) *rail2
35A
GPU1 ----18A-----\
............................\..................../-------------- 12v3 (25A) *rail3*
GPU2 ----15A-------+---=48A----+------*A*----- 12v3 (25A)
30A......................./...................\
GPU2 ----15A ---- /.....................\---- -*B*----- 12v4 (25A) *rail4*
This way it will keep all my loads within the limits
Can anyone tell me if i can actually just splice the 12v3 + 12v4 yellow/black together and then split that back over 3 lines to the cards
And secondly will the load be even at points *A* and *B*
Please dont reply if your going to say buy a bigger/better PSU, i just want some electronics advise?
Ive created a pic that shows better what im after, I just need to know if it would work or any pirtfalls
Physically
35A
GPU1 ----18A-----\
