Hi Guys,
This is my first post, so bear with me a little!
First, my system:
Intel Q6600 G0
MSI P45 Neo-F mobo with 1.9 BIOS (factory installed)
Thermaltake Soprano case
8GB Kingston HyperX T1 1066 DDR2 (@ 800)
Changed the 120mm case fans for Thermaltake ISGC 12's
Changed the Stock Cooler for a CoolerMaster Hyper TX3 with an additional BladeMaster 92 fan in a push/pull config.
Used MX3 thermal paste.
Everything is running fine at stock settings.
I would like to get a bit more juice out of the CPU if I can - The PC is mostly used for work and general internet/mail, but I do game on it and I would like to get as much out of it as I can.
I've done quite a bit reading, and looked at a lot of other posts/forums, but I just can't replicate what others are doing with similar setups.
My problem is this:
I can get the chip stable at 3200 in Prime95, but only if I ramp the core v up to 1.4850. Most people with the same setup and similar cooling seem to be able to achieve this at a much lower voltage - usually around 1.37v or so.
Can anyone point me to where to start looking for the problem here?
I haven't done a lot of overclocking before and I'd appreciate some advice.
Thanks,
SeraphTC
First, my system:
Intel Q6600 G0
My problem is this:
Thanks,
SeraphTC
