Wilhelm
- Jun 16, 2014
Hi all, I'm looking to push this chip a bit further and unfortunately I'm still quite inexperienced with CPU OC and I could use some help!
Below are the system specs and current BIOS settings for the stable build I've achieved and tested successfully for a half week now.
Advanced CPU settings
CPU Ratio Setting: Auto
C1E Support: Disabled
CPU TM Function: Disabled
Vanderpool Technology: Disabled
Execute Disable Bit: Disabled
Max CPUID Value Limit: Disabled
Intel(R) SpeedStep: Disabled
System Performance Settings
Ai Overclock Tuner: Manual
OC From CPU Level Up: Auto
FSB Strap to NB: Auto
FSB Frequency: 410
PCIE Frequency: 100
DRAM Frequency: Auto
DRAM Command Rate: Auto
DRAM CLK Skew on Channel A: Auto
DRAM CLK Skew on Channel B: Auto
Dram Timing Control: Auto
DRAM Static Read Control: Auto
Ai Clock Twister: Auto
Ai Transaction Booster: Auto
CPU Voltage: Auto
CPU PLL Voltage: Auto
North Bridge Voltage: 1.25V
DRAM Voltage: 2.10V
FSB Termination Voltage: Auto
South Bridge Voltage: Auto
SB 1.5V Voltage: Auto
Loadline Calibration: Auto
CPU GTL Voltage Reference: Auto
NB GTL Voltage Reference: Auto
DRAM Controller Voltage REF: Auto
DRAM Channel A Voltage REF: Auto
DRAM Channel B Voltage REF: Auto
CPU Spread Spectrum: Auto
PCIE Spread Spectrum: Auto
CPU Clock Skew: Auto
NB Clock Skew: Auto
I've tested various benchmarks and ran Prime long hours, CPU core temps barely reach 50C so we're cool. I've got a Hyper Evo 212 cooler with MX-4 grease so hopefully we can push this further!
There's a slight concern with the NB heating, it can easily reach 60C though I've been reading it's not uncommon for this board and that's not why I'm making this post anyway.
This is the limit for my FSB with these settings, if I go any higher there will be crashes. If I adjust CPU Voltage at all, I get crashes.
So I'm asking what adjustments could I now attempt to try and increase the clocks? Any additional tips for increased performance, memory settings, anything like that is much welcome, too.
Thanks for your time!
FSB Frequency: 410
PCIE Frequency: 100
CPU Voltage: Auto
DRAM Voltage: 2.10V
NB Clock Skew: Auto
