If i rise my fsb more than 3 from the factory defaults (333 + 3 = 336) then this is what happens...
When turning computer on, it shows up the mobo screen. Then it restarts and shows it again and continues normally.
But if i go to my bios and check the "MB. Intelligent Tweaker" It says that computer failed because of overclocking and so on.
if i would continue normally to desktop, i would have normal settings in use
I tried even loading fail safe settings, change ram to 1:1 ratio, lock PCI-Frequency to 100 and so on. (did i miss something?)
Iv seen many people overclocking theyr q9450 to 3ghz or even more with default voltages, but my system fails even at this level
Could it be a error in Motherboard? or hardware? or just my settings?
(Multipier is low because of energy saving option, automatically rises it to 8 when needed processor for something)
Edit: MY Graphics gard is auto overclocked to
GPU Clock ~ 780 Mhz
MEMORY Clock ~ 1090 Mhz
Edit2: Basicly any changes to fsb ****s up the stability
Build:
Case: NZXT Tempest ATX Mid-Tower Case
Processor: INTEL Q9450 CORE2QUAD 2.66GHZ S775 TRAY
Gfx: CLUB 3D HD 4870 PCIE 512MB GDDR-5 2X DVI
PSU: CORSAIR PSU 620W 12CM FAN ATX EPS12V 80+
RAM: OCZ DDR2 4GB PC2-8500 REAPER HPC€
Mobo: GIGABYTE GA-EP45-DS4
Processor Cooler: Arctic Cooling Freezer 7 Pro CPU Cooler (Socket LGA775)
Compound used: Arctic Silver 5 Thermal Compound (3.5g)
OS: Windows Vista Ultimatum 64bit
GPU Clock ~ 780 Mhz
Build:
