A few more suggestions GTFouts.....
Put both of your spread spectrum (CPU annd GPU) to DISabled.
Play with your GTLRef settings. I see you have them on something other than auto. What I typically do is keep those at auto, find my max overclock, and THEN play with them to see if I can gain a few extra mhz. (thats just what I do, others may do differently).
Thats a decent batch QX9650 of week L739A. The final #s of the batch (646) are a bit sketchier, but I think you should get CONSIDERABLY more with an L739A batch of QX9650.
1.4v max is nonsense IMHO. I would put that CPU higher under CONSIDERABLY more volts, but thats just me. Under good water (which you have) once you get your mounts/fans all the way you like them I would personally max this chip at 1.6v for 24/7 usage, but thats just me and I am known to really like the volts
. I would only use 1.6v if it gains me more overclock, and if it doesnt I would use the least volts possible to achieve the max stable overclock I am looking for.
It is VERY strange IMHO that your temps drop when you decrease your FSB. Temps should be strictly a function of volts, cooling, and ambient temp. FSB and amount of overclock
shouldnt factor into temps in any way at all. But hey...Im not there you are so you would know more than I about your specifics.
Check your secondary RAM timings with the manufacturer of your ram, and check on the ram manufacturers forum to make sure your subtimings are not hindering you. For me personally, unless I am benching and looking to eek every last mhz or 1/100th of a second on a bench I keep all subtimings at auto for my 24/7 rigs.
Have you tried a max FSB overclock yet? Drop your multi as low as it will go, or at some reasonably low multi such as 6X or 7X. Then see what your max FSB that you can acheive with the CPU mildly overclocked. At 6X multi you can get 500fsb and still have that CPU at stock so it shouldnt be a limiting factor. That will allow you to see if it is your CPU, or your mobo holding you back.
Check your ram volts. 2.04v looks low to me but I havnt really used much DDR3 so I could be way off. Start with stock volts as per manufacturers recommendations on your ram, and then if you are going to overclock it at all bump it "a bit".
I would also personally set your FSB termination voltage to auto, but I dont think that is likely causing any problems at the low volts you are currently using.
Good luck man!
