Killjoy7788
- Nov 14, 2017
Hello, I have a question regarding the mounting of my radiator to my to my fan grill. Both links are posted below. I am trying to mount my radiator to the fan grill on the side of a custom-built case, however, the fans for the radiator are tightly squeezed together and the fan grill has about a 3/8" gap in between fans. I am wondering if it is ok to simply mount the radiator with four screws in the center and leave the outer ones unattached. I am not worried about the strength (it is plenty strong) I am worried that the performance will be greatly decreased. just as a reference I am only cooling one cpu and one gpu with 2 360 radiators which i think is overkill but am not sure. Should I try and seal the open parts around the radiator to direct more air through it or not i am pretty stuck with mounting them this way as it is so i am just looking for some feedback thanks so much -joe.t
Radiator: https://www.amazon.com/gp/product/B006097HEC/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
fan grill: https://www.newegg.com/Product/Product.aspx?Item=9SIA8J25343205
