Hey guys, I been looking at this CPU cooler, I may end up selling my Noctua NH-D15 to grab this instead. I want to see if it will block or not block the first PCIE slot so I can move my graphic card to the first one. Anyone running this cooler?
You can try the Noctua NH-D14, it won't block the PCI-E but you have to slot the ram before the block. You will ofc have to worry about higher temps
the D15 is a few degrees better than the D14 and slightly bigger, also either one is significantly quieter than any AIO currently in the market as far as i've seen. The D14 doesn't have the cut fins if memory serves.
http://noctua.at/en/products/cpu-cooler-retail/nh-d14.html
http://noctua.at/en/products/cpu-cooler-retail/nh-d15.html
I still don't see why you're bothering with changing it... how much benefit will you actually get from changing the slot your GPU is in?
If you're serious about changing the motherboard keep the Noctua (easily a match for most high end AIO's), your ears will thank you
Sounds like your real problem is that you don't like your motherboard. I'd probably do something about that before I got rid of a good quality air cooler.
Or bite the bullet and get an aio which would probably be cheaper
I also wish Noctua made black fans because this color crashes with my system. XD
