Hello all, I have a quick question. I have the x6 1090T and asus m4a89gtd-pro/usb3 board. I am able to easily hit 3600MHz stable with the multiplier only. All overclocking has been done with turbo core, cnq, and c1e off.
If I change my bus speed to 333MHz and lower the multipliers to keep HT, NB, and DRAM in spec I can go stable to about 3.8Ghz at 59-60c (loaded), which of course is too hot. I have a different cooler coming, but that is beside the point.
At those settings (3.6GHz on 333MHz bus), when I turn on turbo core the AOD utility tells me it is running at like 6000+ MHz and still using 18x for a turbo multiplier, regardless of what I select in AOD. Clearly this is not the case, since it doesn't lock up or get uber-hot.
I realize of course that AOD is not the best utility, but I like to test with it for stability, then re-set in bios once I find something good, and push on with AOD, etc etc. Also I have read that turbo core is no good, however when doing runs with it on and then off I do notice a difference at various clock speeds. My goal (after I get the new cooler) is to run 3.8GHz with turbo set to 4.1GHz or so (if temps allow). I don't want to run that fast on all cores all the time, but I do find the boost useful in apps that don't utilize 6 cores.
So my questions then are these:
Why does it report 6GHz?
If it is accurate, is there a way to correctly use a lower multi for turbo core?
Is turbo core really that bad and I should just forget it?
Any other helpful advice is appreciated, thanks!
