Hello community, just a quick couple of questions:
I want to improve the temps of my H440 by changing the default fans, planning on getting 1x Corsair AF140 (Back/Exhaust) 3x Corsair SP120 (Front/Intake) and 3x Corsair SP120, two of them will be used on H110i V2 Radiator (Top/Exhaust), so, my questions are:
1. Are SP fans better on this particular case? I've read that on a couple of forums.
2. At this moment, the first slot on top of the case is empty, It would be a good idea if I go 3x120mm on top? Or it would create a "battle" between the first fan on top and the top fan on front? Currently I'm using the "card trick" on that slot (saw that on Reddit, supposedly it helps with airflow, not sure about it tho) Check the image link here
Thanks for your answers!
