- Jul 15, 2013
ok so i have a QX6850 that is liquid cooled via an AIO. temps idle between 37-40c. at max load in prime95 in blend test at stock speeds 3.0GHz temps max out around 56-57c. while not new to overclocking my previous chip was a core 2 duo E8500 im new to overclocking quads so i have a few questions
#1 what temps should i watch out for while stress testing in prime i.e. keep CPU under X temp/temps when stressing for stable speeds
my goal is to reach 4.0GHz stable 24/7
#2 aside from reading the overclocking guide on here is there anything else i should know ABOUT MY QX6850 IN TERMS OF OVERCLOCKING I KNOW THESE THINGS ARE KNOWN TO BE HEATERS
lastly should i test under small FFT's or blend wanna make sure both cpu and ram are stable
also what options do i disable in the bios so while stress testing the cpu will run full speed all the time and not lower its multi and stuff
BEFORE I FORGET im using MX-4 as my thermal paste below is a link to my AIO just incase
http://www.coolermaster.com/cooling/...quid-lite-240/
AIO is run in push pull setup because i had the extra fans lying around
