Hi
A quick question regarding the heat/volts on my QX9650.
I have my CPU under water and the temps are good, on Full Load with realtemp max 55c. (450x9=4Ghz).
I have 1.43v going to the CPU which is already quite high for the 45mm chips( I understand) and I am getting errors on Prime95.
My question is am I safe to put some more volts to the CPU aslong as my temps are ok or is it a case on these chips that I am limited to what volts I can put through it rather than heat issues??
Thanks
Thanks
