- Dec 27, 2012
I just purchased an xspc raystorm rx360 d5 pump dual bay res kit. im currently only going to have a single 780 evga superclocked for the matching videocard block but will get a second next winter. My ? is since I wont have to do too much to just drain and add a second vid card i'd like to add the second rad now while im still buying parts to pipe it up with fill and drain ports in a 900d.
I been trying to find a rx480 in stock to match my kit, hard to find and is very expensive. i see many tell me just to pickup a ex480 [79$] since they half the price, will that be enough or should I just stick to my guns and wait out finding a better deal on the rx480 so both my rad's match.
I also plan to eventually change all the fans on the the rads to corsair SP120 quiet editions. I wanted gentle typhoons but they are nowhere to be found for under 24$ each. for 2$ more i get a pair of corsairs. Will these work as well ?
