Alright... I'm trying to setup a RAID 0 array on my new system. Here are my components:
2x Diamondmax 10 250GB 16Mb SATA Drives
DFI NF4 Ultra D
OCZ Powerstream 520W
San Diego 3700+
OCZ PC3200VX Memory
Here's what happens:
I can enable to RAID array in the bios and configure it using the NVIDIA raid software. I have set it up in RAID 0 "stripping option" w/ strip size set to optimal. I also make it a bootable array. When the system posts, it detects the array and says that everything is healthy. I then boot from the Win 2000 Pro CD to load windows (while pressing F6 to configure the array to work in windows). It asks me to specify the location of the RAID drivers. I plug in the SATA RAID disk that came w/ the DFI motherboard and load the requested files. It goes through this fine but I get the BSOD right after it says "Windows is starting up". It is a fatal error (can't remember which one) but it tells me that it could be the result of a new hardware installation.
I know that the Win2k disk is fully functional because I just installed a copy of Win2k on another computer (single drive). I tried installing the RAID array via the same method using WinXP and everything worked flawlessly. There were no BSOD's. This is currently the way I have it running. I really want to make a dual boot w/ Win2k Pro and WinXP off the same RAID 0 array. Does anybody know whats going on? Any insight would be greatly appreciated. Thanks
-Adrayic
DFI NF4 Ultra D
San Diego 3700+
OCZ PC3200VX Memory
-Adrayic
