I'm looking into purchasing 4 more drives and set up my drives for raiding. I'm hoping you guys can both direct me and answer a few questions I have.
Firstly, I've read through close to 10 pages of the uberungodlysupperdupermerge thread for the Intel Matrix RAID and I feel as though I've learned quite a bit, but not enough. My mobo can do " 0/1/5/10 Matrix RAID" (exactly as Newegg states).
Configuration questions:
1) I want to have my OS's backed up (yes I know I'll have to re-install everything, which I plan on doing anyway--terrible virus) so that eliminates RAID 0. And after those are partitions are backed up, I don't really care if it's stripped or not. I'd rather not have a disk failure, but one can never tell and I don't plan on changing anything for at least 3 years after Win 7 full version), so this is going to be something to last me, so I was going to see what config you guys were thinking about.
2) With the mobo I have the Matrix RAID is used for all of the sata ports? So if I plug in a 1TB drive into the mobo in a few years, then it will be recognized as not being part of the raid but a 1TB drive, right?
3) Is it possible to multi-boot with RAIDing or does each OS have to be on a separate RAID 1? E.g. if I decide to go with RAID 5/10 then each OS would have to be a separate "drive" right?
4) If I decide to add another OS and elminate space on any RAIDed drive, I can use the disk management utility in Windows Vista and up, right?
/config questions
HDD Failure questions:
1) How will I be informed of a drive failure in any configuration with parity or mirroring?
2) In a non RAID 0 config, I would replace the damaged drive and the data would be re-written? Would I be in charge of starting off some software or will the controller on boot begin to re-write the data?
/HDD questions
For what it's worth, unless you guys have some suggestions it looks like I'll probably end up going with a RAID 1/0 set up on the first two drives with OS's and then RAID 5 on the full other 4 (which will become 640GB rather than 500GB drives).
Thanks in advance!
/config questions
/HDD questions
Thanks in advance!
