Fsnow
- Jul 14, 2012
- Eugene, Oregon
Any suggestions for DDR# ram. Have a Asus Sabertooth 990 and a 8120. Planning to put on a Noctua NH14D cooler(which I THINK should clear most RAM) and try to OC into 3.9-4.2 area.
It would be nice to be ready for the next era of CPU and RAM but I'm open. How much do I need? I was kind leaning toward the Samsung 2 X 4 1600DDR green RAM cause of it's ability to be pushed a bit but I guess I should stick to Gskill because it's their forum and I can also move up a bit on total RAM?
Any suggestions on amount or total? Again, I'd like to kinda be able to kinda move into the future a little?
Thanks for your consideration! Please be nice this is my first post and I am turning 65 next month. Time for the younger generation! My first OC was a Pentium from 150mgtz to 187 with dolphin case fans, etc. Since then bought prepackaged systems. Nice and easy. Finally tired of limited options!
I'll likely cross post on GSkill forum but I will try to refrain from excessive bumping, etc.
See any glaring weakness in the build below?
Build:
RAM:??? amount???
CPU: 8120FX purchased(with Noctua NH-14D cooler?)
MB: Asus Sabertooth 990FX purchased(bought just in time to miss REV.2 methinks)
Graphics: 6870AMD single purchased(might do a crossfire or move up to 6950)
PS: Cooler Master RS 700 watt purchased (may need more if I crossfire and 8120?)
Case: Cooler Master Scout Mid purchased
SSD: Samsung 256 830 purchased
HDD: WD SATA 3 2TB purchased
DVD: Asus SATA purchased
OS: Windows 8 Beta (the stock interface sucks big time!)
Build:
RAM:??? amount???
