- Thread Starter
- #21
I dont understand my motherbaord at all right now; at all default settings which is 1st temp target for the cpu fan to hit %20 speed is 41c degree and in that case my situation i told above happens even if i get that temp target to 60c degree. That bit is important; '''%20''' and the fan spin at 1700ish rpm.
And i just wanted to get my cpu to 3,9ghz with 1,3375volts which was okay before and and still seems stable right now, not changing anything else. Guess what happened? Now my cpu fan is spinning at 1300ish rpm on idle when i get the RAM to 2773Mhz which was 1700 before when the cpu was at default settings. If someone can understand whats going on please illuminate me...
Edit; Btw just checked gpuz and its showing my currently overrided cpu Vcore voltage;
