I'm getting ready to buy an Asus P9X79 Pro with an i7 3930k, and I'm trying to make a wise RAM choice, starting with the Asus tested modules. I want to get 32 GB, for which there is only one choice in that list, the Corsair CMT32GX3M4X1866C9, which is DDR3 1866, four modules.
However, the Intel website says this CPU only supports up to DDR3 1600. So checking the Asus list for that speed, I see the G.Skill F3-12800CL9Q-16GBXL, 16 GB, four modules, and since the Asus motherboard has eight slots, I can buy two of those and get to 32 GB for a lot less $ than the Corsair kit.
What I would like to know is:
1) Would using all 8 slots be the same regarding stability and speed than using four? (this is of course if I underclock the Corsairs to 1600, since it's the highest the CPU can handle apparently).
2) Does having twice the number of modules, especially Non-ECC RAM, mean twice the possibility of errors?
3) What happens if I get the 32 GB Corsairs and I don't underclock it to 1600 in the BIOS? Will this mean more chance of errors since the CPU says it can only handle up to 1600? Or does the BIOS automatically slows it down to 1600 when it detects that CPU?
Thanks
Thanks
