- Oct 11, 2002
- The Empire State
Dam that's hawt! Gratz on the new toys! I want one too, but I ain't seeing that in quite a while
check the pics 4.2ghz in the 60s with the stock cooler
WTF??? Time to start spamming D-tek customer support.
What ver. Vista you use? 32 or 64 bit? which is the better choice?
What about gtz, ek supreme and other blocks? . You're not going to leave that out are you!
Check my sig I already have a Fusion ver 2.0 and I just want the LGA 1366 clamp assembly so I dont have to buy a whole new block.
What I meant was, why did you mention dtek v2 only? Why not the other top performing blocks? The GTZ seems unlikely to have a 1366 mount though.
mgoode,
to get a slight increase in superpi times, get a ramdisk package. for me in 1m i lost about .02secs by having superpi on a ram disk vs with out. as well, as noted with brolloks runs, superpi also loves ram bandwidth, use tri channel. as i noted from his numbers wprime for 32m has the same time between dual vs tri but 1024mb takes a hit in tri mode. now his superpi time on the other hand went down on 32m in tri mode vs dual, meaning it was faster in tri mode.
Because I only have Dtek block. The other block are great too. fyi...Here is the new GTZ and you can buy the mounting separately.
