had built this PC about a year ago, and it ran excellent for a year. One day, recently, this random crackle/skip started to happen. It was happening regardless of which program I was using. It is most noticeable when watching Netflix, recording music, and opening a new tab(both Google Chrome, and IE).
My first thought was the RAM, Sound card, or GPU. I have a back-up PC, and xtra parts. One by one, I started with the process of elimination. I changed out RAM, GPU, and Audio with no results. After that, I was left thinking it must be the MB or CPU. I wanted to update anyhow, so I grabbed a new MoBo and CPU, same deal. Somewhere in there, I also Changed out to one drive with a Fresh Windows install, both on my newer SSD, and another HD, both with same results. Just to be sure, I had unplugged every single extension header, and peripheral. I also had thought CPU temp could be the issue, as the old APU would run an Avg. of 40-50C. With the new CPU I added a 120mm cooler. Avg. CPU temp with the new processor is somewhere between 15-25 degrees C. so I am counting that out too.
Each time I made a change, it seemed better for about an hour or so, then started again, and since then, has been getting worse.
At this point, everything has been replaced. Unless it's because my tower(case) is the problem, lol, then I am down to the PSU. It seems very odd, and the PSU seems a very unlikely candidate for the problem. I am at the point where I just want to buy a whole new PC, DOH,.. I already have!,.. lol. My PSU is still under warranty from last year, and I have the RMA# already. I will send it in tomorrow. I am just dreading a week later, when I install the new PSU, and still have the same issue! Any thoughts on this?
It doesn't seem to matter what my system is, as the issue was there with the previous system too, however, this is what I am working with now.
AMD FX-8350 Eight-Core Processor 4.00 GHz
GIGABYTE GA-990FXA-UD3 AMD 9 Series Motherboard
16GB Crucial Ballistix, PC3-10600, DDR3-1333MHz
OCZ ModXStream Pro Power Supply - 700-Watt
MSI R7770-Radeon HD 7770 Video Card - 1024MB
OCz Vertex - 3 SATA III - 120GB SSD
WD VelociRaptor 250 GB Sata 6 Gb/s, 10,000 RPM, 64MB Cache
Windows 7 Ulimate 64bit SP1
