- May 7, 2012
- Dorset, UK
I've started noticing this today after installing a new disk drive yesterday and re-arranging most of the cables in my case. Every few seconds the airflow noise seems to increase for a few seconds and then decrease again. The change seems quite random but is very abrupt. As far as I can tell, it seems to be coming from the area around my front intake fan.
It only happens when I have the case side on so it must be related to turbulence or pressure inside the case. It is a Zalman Z11 Plus case with stock rear and top exhaust fans, the stock front fan moved to the bottom intake, and a Cooler Master Sickleflow on the front intake (where the change in noise seems to originate). All case fans are running at full speed.
Any suggestions on how to solve this? I would connect the Sickleflow to the motherboard to try running it slower but the cable is too short so it has to be connected to a molex.
