Sorry, my bad...I need to update my signature....Give me a bit while I update it.Might be that H100 AIO is at it's end cooling wise. Have you reseated the block on the chip?
Thank you, EarthDog! Do you know of a tutorial on negative offsets?100% normal for a stress test. That's how these chips roll on things like this. What you can do is use a negative offset and lower the stock voltage a bit (try 0.05V) and see if it's still stable. That will save you a few C and may hold clocks longer.
Raise them? Sure! Otherwise, boards tend to throttle the CPU ~10C below where the chip shuts off to protect itself (100C for his CPU).Also you can set temp limits in the bios as a safety precaution.
Never said "Raise them" I said "Set them"Raise them? Sure! Otherwise, boards tend to throttle the CPU ~10C below where the chip shuts off to protect itself (100C for his CPU).
