- Feb 23, 2004
- Charlotte, NC
im VERY satisfied with mine as well, though im on stock cooling
MasterCraft said:I can't wait to see what bat's and my 3.8's will do
batboy said:I got mine up to 4.4 gig tonight. I haven't tested for stability yet. it's pretty much maxed out on air.
Please start a new thread when you get this all set up.MasterCraft said:Jesus, I can't wait to see what bat's and my 3.8's will do
especially if he's hitting close to 4 on air and I'm going phase change
Para said:Does anyone recall there idle/load temps at stock speeds?
uclajd said:OK, you got a D0 stepping (second-to-last). If you hit stable 4.0+ on air at stock, you have a great chip.
FYI, these Pressy's will overclock more on more volts, but that is precarious on air, due to the added heat.
Here's a wattage calculator, FWIW:
http://newstuff.orcon.net.nz/wCalc.html
If 4.0 is stable on air at stock volts, on water @1.6v that thing should do 4.2.
BTW, do you know the sSpec# number for that chip? It's on the box if you bought retail, and it's stamped on the headspreader.
The sSpec# number is in red triangle. If we know the sSpec# number we can get the needed values for the wattage calc.
Good luck,
JD
