- Feb 22, 2009
*thumbs up*
Start with the Basics. It seems you've become confused and lost track of where you are at with this overclock. Reset bios to optimized settings. (Default) Make sure you turn all turbo modes off for memory and cpu. (Increases stability). Run your memory at stock settings to start with when you are trying to increase your clock speed. Make sure in BIOS That you manually set your default ram speeds and make sure they are either running at the default frequency or just below it. Start overclocking your processor first then adjust the memory timings and see if it's stable. Try and find out what voltages others are using for successful overclocks to get a general idea of what kind of voltage you should be using at what clock speed. Good luck!
Please read the whole thread. HH is starting over using miahallen's guide. He is first determining his max bclk and then RAM speed. Let's not confuse him. It's bad overclocking form to try using someone else's settings for your overclocking.
Using anyones guide is bad reference unless you have the exact same build..... Pure basics of any overclock is to not screw around with everything at once then try and figure out what failed... I simply told him to do one thing at a time so if something fails he knows what it is...
no point in trying to monkey with the memory. it's at 606mhz now, and my next option is 800 something. this stupid board won't let you set your own ratio, so tomorrow night, i'll get to part three.
thanks!
