Looking for a little advice as I have been out of the game for a number of years. I originally bought a Danger Den Waterbox about 7-8 years ago and was intending to watercool but time and life got in the way. It is finally time to update this rig and I want to keep the case as it still looks pretty.
My goal is to just use a closed loop CPU watercooler and the card I am looking at (a 1070) has a built in closed loop as well.
The case has 3 120mm fan slots as it stands. One on the top and 2 down low on the front panel. Based on the closed loop systems I am looking at that takes all available fan slots and I am concerned about the normal air flow for cooling the non watercooled components.
Looking for some advice on where I should maybe consider drilling out some more fan slots and how all the fans should be oriented for the best performance in air flow. (I am not 100% sure if I remember what the standard direction on the radiator fans are for the 2 closed loop devices.
Here are the parts for closed loop that I am looking at as well just for reference.
CPU Closed Loop - Deepcool Gamer Storm https://www.newegg.com/Product/Product.aspx?Item=N82E16835856078
GPU w/ Closed Loop - EVGA GTX 1070 https://www.newegg.com/Product/Product.aspx?Item=N82E16814487264
Been coming to this site for years but this is my first real attempt at putting together any kind of watercooling in years so I appreciate any advice from people.
