- Aug 22, 2012
Hello, I'm looking to build a new computer. I was wondering if I could get some advice.
I Currently own:
Memory Storage:
Intel 320 Series SSDSA2CW120G3K5 2.5" 120GB SATA II MLC Internal Solid State Drive (SSD)
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167050
Seagate Barracuda 7200.10 ST3750640AS 750GB 7200 RPM 16MB Cache SATA 3.0Gb/s 3.5" Hard Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148134
Video Card:
EVGA 01G-P3-1373-TR GeForce GTX 460 (Fermi) Superclocked EE 1GB 256-bit GDDR5 PCI Express 2.0 x16 HDCP Ready SLI Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130567
Power Supply:
Ultra LSP650
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3276573&CatId=1483
Case:
Thermaltake Black Armor Full-Tower ATX
http://www.tigerdirect.com/applicat...WEBLET03ORDER-_-03order&SRCCODE=WEBLET03ORDER
Heatsink:
COOLER MASTER Hyper 212 Plus
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
For reference my current MOBO and CPU that I want to upgrade are:
Asus P5N-E SLI Motherboard - NVIDIA nForce 650i SLI
Intel® Core™2 Quad Processor Q6600 (8M Cache, 2.40 GHz, 1066 MHz FSB)
I am sure I can re-use the case, video card, and drive, how about the Power Supply and heatsink?
Should I upgrade my video card or will this hold for a bit longer?
Could I get some recommendations for MOBO and CPU that are competitively priced as offer a great bang for their buck?
MOBO features:
I would like to have a USB3.0 port
MOBO worries:
I have currently Asus P5N-E SLI Motherboard - NVIDIA nForce 650i SLI
*It has horrible PCI express location so the Video card basically hovers above the SATA plugs. Out of 4 SATA plugs I was only able to fit 2 SATA devices in. And that was with a third party low profile 90 degree turn cable. The point is I would like to use all the features of the MOBO (even with a huge video card which is the current trend)
*The NVIDIA drivers for the SSD are not great and either don't support TRIM or support it incorrectly. I have to specify to use windows7's SSD drivers...not ideal.
CPU worries:
I would want an i7 I think. The more components I can re-use the more price is not an issue.
Thanks for your help!
Let me know if you need more information from me.
oh, almost forgot: Intended Uses.
I'm a gamer, (I dabled in OC'ing previously but I don't think I will do that to my next system). I play Starcraft 2, Diablo 3, and other graphically intensive games. I do some audio recording of guitar + vocals and audio editing (not much).
[Edit]
I plan on looking into overclocking. I don't have a specific plan for it right now
I'm in the US ordering from the US
I have Windows 7 and will get windows 8 (probably)
I have dual HD monitors (LED backlit), keyboard (Logitech G-15), and mouse
I don't plan on SLI or CrossfireX
I Currently own:
Memory Storage:
Video Card:
Power Supply:
Ultra LSP650
Case:
Heatsink:
MOBO features:
MOBO worries:
CPU worries:
[Edit]
