- Dec 7, 2003
Watercooling Shopping List!
I’m looking to build a 2 loop system. One loop devoted to the cpu and a completely separate but identical loop for the gpu.
Please weigh in on suggestions!
Also got a few general questions, highlited.
This is going to be for my main personal gaming system.
I pictured a physical layout of each unit, but it was sort just a rough picture in my head:
Here’s my hardware:
i7 2600k
Asus Maximus IV Extreme
Corsair 2x4gb Vengeance
Zotac GTX 680
Corsair HX750 PSU
I currently already have:
1 stock MCP35x
2 Alphacool Monsta 3x120 radiators
I Need:
1) Tubing
In the past I’ve stuck to ¾” OD / ½” ID. Any reason to change?
2) Fittings
Is there a performance difference between barbs or compression fittings?
Compressions fittings look cleaner, but seem to cost more?
Maybe go with compression fittings in the visible portions of the build?
3) Reservoirs
Big, small, my system can fit any.
Should I go with a combo reservoir/pump?
EK res/pump top x 2?
http://www.frozencpu.com/products/1...ng_DDC_Swiftech_MCP350355.html?tl=g30c107s152
Or
Stealth Res
http://www.sidewindercomputers.com/st225mureexw.html
+ XSPC pump tops
http://www.svc.com/ddctopc.html
I lean towards the tall cylinder type reservoirs because I feel like they may be easier to fill and have a tendency to suck down bubbles less.
4) CPU block
Any recommendations?
I’m leaning towards EK supremacy for looks and performance.
http://jab-tech.com/EK-Supremacy-CPU-Water-Block-Copper-Plexi-pr-5003.html
Should I go with the Nickel plated version?
5) GPU block
Think I’m going to splurge for a full cover for my GTX 680.
Leaning towards Heatkiller
http://www.frozencpu.com/products/1...Coverage_Water_Block_15520.html?tl=g30c87s143
And backplate:
http://www.frozencpu.com/products/1...Design_GPU_Backplate_16003.html?tl=g30c87s143
Once again, Nickel Plated or not?
6) Fan control.
I’m going to have 4 banks of 3 fans (2 3x120 radiators, in push-pull).
That’s 12 fans to control, potentially 4 banks of 3 fans.
I’m thinking Scythe KM03 x 2.
http://jab-tech.com/Scythe-Kaze-Master-Pro-Black-KM03-BK-pr-4639.html
7) Other
Silver coils
http://www.frozencpu.com/products/1...r_Tubing_Reservoir_Strip.html?tl=g30c103s1676
Color additive. Make it red.
http://www.frozencpu.com/products/1..._-_15mL_-_Blood_Red.html?tl=g30c103s185#blank
Temperature displays (x4--into and exiting each radiator)
Bitspower:
http://www.performance-pcs.com/cata...e=product_info&cPath=60_392&products_id=32010
8) Second Pump
MCP35x
http://jab-tech.com/Swiftech-MCP35X-12V-DC-Pump-pr-4750.html
9) Fans--looking to keep it a little cheaper.
I’ve got 3 Yate Loon slows.
I’ve got 3 Coolermaster slows.
I’ve got a box of Sanyo Denkis in case I ever want to try some serious air movement.
Need: 6 more 120mm fans.
I’m thinking 6 of these YL D12 38mm thick. $7 apiece:
http://jab-tech.com/Yate-Loon-120-x-38mm-D1SL-12D-pr-4335.html
Anything else anyone can think of?
Thanks!
Navig
Here’s my hardware:
i7 2600k
Zotac GTX 680
Corsair HX750 PSU
1 stock MCP35x
I Need:
1) Tubing
2) Fittings
3) Reservoirs
Or
Stealth Res
+ XSPC pump tops
4) CPU block
5) GPU block
And backplate:
6) Fan control.
7) Other
Silver coils
Bitspower:
8) Second Pump
MCP35x
Thanks!
Navig
