- Jun 10, 2014
- san jose CA
- Thread Starter
- #41
There's an app ? lolMike, your sig isn't showing because you're posting from mobile.
Try the app instead
Try the app instead
Audible noise. Prolly the pump. Looking at the pic, the side of the case with the radiator/fans is very small holes. I bet your blocking 80% of your airflow from the radiator fans.
You need to cut the case.
hmmm it seems to be running a bit warm at idle . load temperatures on a 4.5 ghz 1.3 oc saw me going all the way up to 78c. and there was some audible noise . whats going on ?
The side of your case says no airflow, help meee! Cut me case wide open so I can breathe!
Think about it. Look at it. Think basic physics. Airflow is paramount for watercooling. And you have very little through the rad. You could buy some higher RPM fans.
You could cut the case and buy available covers from Performance PC that will cover the hack and look good. Or even some wire fan shrouds.
It s about performance first, then pretty. A dogfish ain't pretty but it has been around for a few million years eh?
