- Jan 7, 2005
Ok thank you Rolling Thunder
witch one should i choose Modular ?? i dont know the difference forgive me
Modular generally have cables that can be removed if you don't need them and non-modular have all their cables hard-wired inside the case. Click on a few of each and you can see the reviews.
My rule is generally if you're not going to SLI then a modular is better. You can eliminate most of the cables you don't need.
If you are going to SLI then you will probably use most of your cables anyhow.
