- Jan 13, 2005
ok I have a weird one that I have been trying to get figured out.
I got about 26 new desktops that are going to replace the 12 year old systems at the company I work for and they all came with a trial version of office installed.
Its not a Click to Run version of office that we need to use for some of the beefer apps like Visio and what not.
I can install the Click to Run base version of office (word excel outlook etc.) along side of it but it wont over write it.
It seems to be loaded like some of those stupid games are that show up on your start menu from time to time.
you can "uninstall" it from the start menu but it only removes it for that user, when some one signs in on AAD or a new local user is created it brings it back again.
it does not show in the add/remove programs option in the control panel
The fix it tool for office does not see it
I found some power shell and command lines to run and it does not remove it either.
all I need to do is be able to remove it on a computer to computer basis with out having to re install everything over a otherwise perfectly good factory install of win 10 pro from Lenovo. Just trying to save time here. Prep time from unpack to deploy after installing all of our applications and setting up AAD is about 15 minutes per, reinstalling over is going to create a huge headache and probably triple that time.
In case any one is wondering the computer model is a Lenovo ThinkCenter 710t, i3-7100, 1x8GB DDR4, 500GB HDD, No ODD, No GPU. Pretty bare bones but better than the C2D and 4 gigs of DDR2 they are replacing.
Any ideas?
Any ideas?
