First, let me apologize for the rather blunt title, but that is essentially what I have done.
I partitioned very poorly as a result of grossly overestimating the amount of space to dedicate to each Linux distribution, and as a result I have a far smaller Windows partition than I should, and I cannot conceivably reallocate the unpartitioned space to Windows.
In an attempt to fix this, I booted into Linux and copied several of my larger games as well as the C:\Users folder over to the newly-made partition.
I replaced the actual folders with symbolic links.
Then, when I attempted to boot back into Windows, I was able to log in normally, but then it said "preparing your desktop," which was unexpected as my desktop is set up. When I got there, it presented me with a blank desktop, Windows Explorer was not running, and my data was gone.
I received the following error:
Since I merely copied it over to a different hard drive, I have not actually lost anything, and I know how to fix it. What I would like to do is make it so that it works how I have it (I will obviously have to use different methods, but you likely understand what I am trying to do).
Any suggestions?
Code:
C:\Windows\System32\drivers\Desktop refers to a location that does not exist
Any suggestions?
