Nothing wrong with that. Believe it or not, Antec makes some outstanding case fans. Their Antec Big Boy 200mm case fans are some of the best and quietest I have ever used. Of course, like most companies, they have several quality "tiers". Their budget, entry level fans are great at moving air, but are not as quiet as their upper tier models.The fans even said Antec on them lol.
If your 4 intake fans are pulling through air filters, I don't see where you need to do any "configuring". Dust certainly is important to manage but ensuring good "flow" of air moving through the case is more important.Now I'm just configuring them so that at idle I have positive pressure as it's dusty here in Los Angeles and we have a puppy.
I have to wonder, however, if you really need that many fans?.
If it is tat bad you may want to consider taking the sinks off and using a higher grade of thermal interface material, be it pads or simply TIM
They have addressed this on the z390 platform with heat pipes and a fin array
That is pretty extreme, fan not cutting it ?
you will have to let us know how much cooler the Master runs
Now you have peaked my curiosity
I will have to check mine
