Been looking at a bunch of fans on Newegg, comparing Cougars to Corsairs. It looks like the Cougars have better specs pretty much across the board when comparing them to the Corsair model they are compared against. Overall the Cougar looks much more attractive. Still deciding between the H100i and the H90 but leaning toward the H90, seems to get more positive and safer reviews. These fans are for case replacements.
Cougar: 1500RPM, Airflow 70.5CFM, Noise 17.9dBA
Corsair High Performance High Static: 2300RPM, Airflow 62.74CFM, Noise 35dBA
Corsair Quiet Edition High Static: 1450RPM, Airflow 37.85CFM, Noise 23dBA
Corsair Performance Edition: 1650RPM, Airflow 63.47CFM, Noise 30dBA
Corsair Quiet Edition: 1100RPM, Airflow 39.88CFM, Noise Level 21dBA
Cougar CF-V12HPB 120mm:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835553006
Corsair SP120 High Performance High Static:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181026
Corsair SP120 Quiet Edition High Static:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181024
Corsair AF120 Performance Edition:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181022
Corsair AF120 Quiet Edition:
http://www.newegg.com/Product/Product.aspx?Item=N82E16835181020
One question about fan replacement on an H90. The stock fan runs at 1500RPM, 94 CFM, 35dBA. Although the Cougar 140mm is nearly half the noise, it runs at 1200RPM, 70.5CFM. Think that would be a noticeable performance drop? I would push pull, so maybe a combo of the H90 stock fan + the Cougar, or Cougar x2.
