- Jan 12, 2013
- on your window sill staring at you
^that
I'm not too concerned with the backing when its time to take it off, but I just have zero desire to take the mobo out anytime soon. It really does look like you could use the rear plate for the H100i. Its just a matter of screwing something in.
So i figured out what the issue was with my temps. Basically: definitely set it up as intake rather than exhaust. And make sure the hoses are at the bottom of the radiator and not the top. These units tend to have an air pocket at the top of the radiator, if the hoses are there you will suck air into the pump. bad news. I dropped 15c by going bottom hoses w/ intake fan set up.
Hoses to the bottom actually traps more air. You did better by actually tilting the case as you learned more about watercooling in general? Became a better bump the pump bleeder? Not rushing it as much?
Am I correct?
Anyhoo, glad it's better for you, that's all that matters.
