- Apr 26, 2012
- New York, USA
At the stock 200 HT Ref., the first frequency is 800, followed by 1066, then 1333, then 1600. The ratios, from low to high, are 4, 5.34, 6.665, and 8. That's why your first divider is showing as 1068, because that's what it is.
So, by my math, an HT Ref clock of 250 will get you ~1333MHz on your ram by using the 1066 divider, and 250*15=3.75GHz. In order to get 1333MHz on the next lowest ram divider, you will need an HT Ref clock of about 333. That's probably higher than your motherboard will support.
Now, your memory may support the 1424MHz that you show as the second option in post 80. The only way you will know is if you try.
